Pinzgauer 710M Conversion - Build thread
MTPinz
Re: Pinzgauer 710M Conversion - Build thread
Post by MTPinz »
This looks like it's heading in the right direction, nice work! I love those hardtops...wish I could find them stateside!
63rover
Post by 63rover »
Looks like the conversion is coming along very nicely. I just noticed that you are planning to put your lithium batteries on the floor near the transmission access plate. I have noticed that cargo on the floor in that area gets quite hot from the proximity to the exhaust, heater, etc.. You may find some insulation to be necessary or even relocation of the batteries. I would hate to not mention it and hear that something unpleasant happened. Good luck with the project! -Cheers!
Hugues
Post by Hugues »
Box mounted on Pinz 8) 8) 8)
Same weight as the tarp and structure I removed, so net weight gain = 0 :D
https://youtu.be/sDy6xW7xUP8
box on Pinz.jpg (137.2 KiB) Viewed 3729 times
Hugues
From Switzerland
Hugues
Post by Hugues »
63rover wrote: Sat Apr 22, 2023 1:41 pm Looks like the conversion is coming along very nicely. I just noticed that you are planning to put your lithium batteries on the floor near the transmission access plate. I have noticed that cargo on the floor in that area gets quite hot from the proximity to the exhaust, heater, etc.....
Thanks for pointing this out.
The floor is insulated around the battery. And I planned for a ventilation of the electric box (which connects to the battery box) so I can remove excess heat. I see my battery can handle discharge up to 60C. But good to know. I'll probably build an extra air gap. Thanks.
Hugues
From Switzerland
Hugues
Post by Hugues »
I've been posting update on 3 different forums,
that's a bit much,
you can find my latest update on this thread:
https://expeditionportal.com/forum/thre ... ad.237457/
Hugues
From Switzerland
Hugues
Post by Hugues »
Short update
my build channel on youtube:
https://youtube.com/playlist?list=PLA_n ... bJsyJ7DOib
Hugues
From Switzerland
