Winch Info
Re: Winch Info
I have yet to get any info as to whether it worked great, failed miserably, or hasn't been put to the test.
Re: Winch Info
I have not dealt personally with the man but I have not seen anything he has made that was anything but excellent work.
This is just one more example.
Re: Winch Info
A closer view of the winch bumper Andre built for me. I added the aluminum fairlead for the synthetic cable (I hated the steel line) and this location gives a great pull angle, almost exactly where the factory pintle is located. The winch is mounted higher so it doesn't impede airflow into the grill.
Re: Winch Info
And Jim's was more stout than usual as he had plenty of imput on the build. Truely a one of a kind bumper.
Re: Winch Info
Next question: winch line. Which one to use Amsteel blue or Spyder black. Warn uses the Spyder in their winches on the website but Amsteel was
recommended for the pinz. What ever I use I will need a new fairlead for the line to pass through.
This last weekend using the winch (I had never extended as much cable before) I noticed a big gouge in the line and only partial strands were left.
This is very scary to me and it's time to replace the line. Only used the winch twice and I am wondering about the break in the cable???
I am aware of the abrasion factor of synthetic but not sure of the expansion of synthetic line vs steel cable.
Where to get new line? Who is a source?
Morris
Morris
Re: Winch Info
Best deal that I found was http://www.jeepswag.com/winchline/index.html#TWL. Seemed to be a good price and good quality, too. I've only used it once (to right a small tractor) but it was SO much nicer than frayed steel cable.
I went with 75' of 3/8" line; I have straps and cables if I need to extend the reach. I'd rather have more safety factor with a bigger, stronger line vs. longer reach. I also found this snatch block to use with the line http://www.amazon.com/dp/B000PD7DIO/ref ... 1_ST1_dp_1 which is much less $$$ than I expected it should be. Haven't used this yet, but it is greaseable and very heavy duty and the 3/8" line won't be crowded in the pulley groove.
Re: Winch Info
IMHO, if you have a lot of weight on the front end, you should look at TD Pinz coils. I have them in my truck and I know others do too.
Re: Winch Info
Samson AmSteel-Blue is the way to go but the Warn Spydura is basically the same material (both are 12 strand HMPE fibers)
3/8" is a great size and has an ABS of 20,400lbs and a minimum BS of 18,400lbs and at 3.5lbs/100ft it will give your front springs a break
If money is no object MasterPull takes Amsteel-Blue and puts a nice braided cover over the entire rope http://www.masterpull.com/
Viking offroad makes great winch lines as well but bottom line is you can go to any marine store (physical or online) and buy 3/8" (9mm) Amsteel-Blue and spend a lot less for the same product.
Buy a few feet extra and make some soft shackles while your at it
Re: Winch Info
Thanks for all the replies to my winch issue. It is great that there is a place to go for help and information.
Thanks to Vince for keeping this site going.
I also called Scott who gave me valuable information. Support our sponsors.
- audiocontr
Re: Winch Info
I need to pick up some synthetic lines. Way too much weight up front.
- My current guard and winch set up. The SMART car is the fiance's (Just sayin)
- 279361_10151187248221690_1409221000_o.jpg (410.5 KiB) Viewed 4746 times
- I had a front guard very similar to the one above and it worked well (BEHIND the chair)
- 269475_10150224913267397_5745807_n.jpg (106.39 KiB) Viewed 4746 times
Re: Winch Info
That guard (behind the chair) was one of my 2nd generation Winch guards. I stopped mounting them over the bumperettes for 3rd generation and beyond. I found under "Heavy Winching" the guard would bend and pull at the bumperettes because they weren't as sturdy as the body mounts.
Re: Winch Info
Makes me wonder how many of us have both a Pinzgauer and a Smart car. We really love both of them in different ways. wife would like it if I could make it so the smart would fit in the back of my 712 so she could go into towns when she was tired of wheeling. I told her I would consider doing that with a haffy but not the smart.
Re: Winch Info
Now your talking!4x4Pinz wrote:
SNIP
Smart car is good for seats for Pinz
