If the insert is missing, the hole in the drum is M12x1.5
Standard M12 i.e. coarse, is 1.75
Maxtrax
Re: Maxtrax
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Re: Maxtrax
OK - good to know. Looking at the parts manual I can see that I used M10 bolts. I didn't notice any inserts.
I don't know why they chose to tap M12 holes and then fit M10 inserts.
Re: Maxtrax
Cast iron is fairly soft/brittle and wouldn't last long. 12mm just happens to be what you need in order to fit an M10 insert (which is made from hard spring steel)
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
