Eberspacher BN4 Questions
Posted: Mon Feb 18, 2013 8:06 pm
by Tyler
I recently aquired a BN4 heater out of an 712. I need a 24V fuel pump to get fuel to the fire. Anyone have a part # or recommendation for this application?. Its pretty much the last piece of the functional puzzle to get it working. However, ive also heard of someone on here using the factory fuel pump for the truck and simply putting a "y" fitting inline to supply both the truck and the heater simultaneously. I dont necessarily like that idea. It may work, but it doesnt sound safe or reliable. Thoughts?. Ideas?.
Thanks.
Tyler
Re: Eberspacher BN4 Questions
Posted: Mon Feb 18, 2013 8:36 pm
by westernair
Bn4's were used in VWs as well. Might just use a 12 v from a VW and get your power from you 12v converter for it.
Posted: Wed Feb 20, 2013 9:34 am
by Q
ebay germany right now:
http://www.ebay.de/itm/Pumpe-fur-Standh ... 500wt_1268
may ship to USA if you ask, but unfortunately seems to not accept paypal...
Posted: Wed Feb 20, 2013 11:08 am
by westernair
Q good find, I don't think these come up to often, I would get it.
Posted: Thu Feb 21, 2013 6:27 am
by spandit
I've got a complete new BN4 to sell if someone wants it - no takers on eBay recently
Posted: Thu Feb 21, 2013 2:01 pm
by westernair
spandit wrote:I've got a complete new BN4 to sell if someone wants it - no takers on eBay recently
Yours for sale, is it a military 24v unit or a 12v civilian unit?
Is is complete with the special pieces to vent out the side plate and run heat to the back?
Lastly what are you wanting to get for it?
Posted: Thu Feb 21, 2013 2:32 pm
by spandit
It's a military 24V unit but designed for a Land Rover so to draw air from the side would need a mod. I was looking for £350 but open to offers
Posted: Mon Feb 25, 2013 5:42 pm
by ranicotra
found this one on eBay: BIN for $400. currently no bids at $300
http://www.ebay.com/itm/Eberspacher-vw- ... es&vxp=mtr
-Rick
Posted: Tue Feb 26, 2013 2:12 am
by spandit
That one is 12V. Mine is 24V and new (unused)
Posted: Wed Mar 06, 2013 3:17 pm
by audiocontr
I'm confused.
The stock Heaters had an external 24v pump? Where is it mounted on a K?
Posted: Wed Mar 06, 2013 6:04 pm
by djw
audiocontr wrote:I'm confused.
On my K the electric metering pump is installed behind a panel in the right front wheel well by the tank. When the heater controller is calling for fuel, you can feel or hear the pump ticking if you listen closely. But then again my heater is a slightly different model B3LC used in the factory refurbs. There is a spec for volume of fuel over time in the Eberspacher manuals and the pumps are set at the factory. Otherwise you get smoke or flame outs.
If the pump is not ticking, or the tank is low on fuel, or the pump is not metering fuel, you won't get heat. The supply lines from tank to pump in mine had to be replaced, then there was heat.
Posted: Fri Mar 08, 2013 12:13 pm
by audiocontr
thanks!
