Page 1 of 3
Hi-Lift 4XRAC Mounts
Posted: Wed May 22, 2013 6:49 pm
by berger
I have read a few posts on the hi-lift mount guys have used on the noses of their Pinz's, and I just wanted to confirm if this was the part? Obviously drilling is required....
- 144217_lg-1353346143.jpg (17.42 KiB) Viewed 6197 times
Re: Hi-Lift 4XRAC Mounts
Posted: Wed May 22, 2013 6:55 pm
by mm58
Wow, I just bought one of that very same mount kit yesterday. I plan to mount them on the placard plates on the nose of my "K". If it goes according to plan, no new holes will be required to be drilled into the body
Posted: Wed May 22, 2013 7:06 pm
by berger
mm58 wrote:Wow, I just bought one of that very same mount kit yesterday. I plan to mount them on the placard plates on the nose of my "K". If it goes according to plan, no aftermarket holes will be required to be drilled.
Awesome Mike! Could you take some pics of your install?
Posted: Wed May 22, 2013 7:54 pm
I know ScottishPinz used the radio tube mount points on his 710K so no new holes drilled.
viewtopic.php?f=6&t=8069&start=15
I know you have a 710M so not really the same just passing it on
GenevaPinz mounted his inside his 710M
viewtopic.php?f=18&t=6897&hilit=Hilift
Posted: Wed May 22, 2013 8:08 pm
by berger
I plan on using the same mounts as the tube holders, but I read elsewhere....4X4Pinz.,,had to drill the holes for the centre bolts, versus the side holes.
Sent from my Mobile
Posted: Wed May 22, 2013 8:32 pm
by mm58
I'd gladly post pics if I can figure out how. I'm taking VGA sized .jpg's an when I try to upload any to a post, I get an "invalid" result.
Posted: Wed May 22, 2013 9:07 pm
by 4x4Pinz
mike, send them to me and I will post them for you. I can resize them so you can post them also.
Posted: Wed May 22, 2013 9:16 pm
by 4x4Pinz
berger wrote:I plan on using the same mounts as the tube holders, but I read elsewhere....4X4Pinz.,,had to drill the holes for the centre bolts, versus the side holes.
Sent from my Mobile
The mounts I used which required drilling were the ones in the photo. They were old school Hi Lift jack mounts. Have not seem them for sale in a while.
Posted: Wed May 22, 2013 9:29 pm
by 4x4Pinz
Pics of MM58's jack mounts
Posted: Thu May 23, 2013 5:40 am
by audiocontr
I used nylon spacers, washers and a long bolt w wing nuts. Worked great. Used stock holes. All from Home Depot.
Posted: Thu May 23, 2013 7:22 am
by berger
Thanks guys!
Posted: Thu May 23, 2013 7:49 am
by mopar
That's how I mounted mine. I used some 1/4-20 rivnuts on my 712.
Posted: Thu May 23, 2013 9:37 am
by Andre
I prefer this method.
Posted: Thu May 23, 2013 9:52 am
Andre wrote:I prefer this method.
Are those your mounts?
I like that as it uses the tube mount bolts correct?
Posted: Thu May 23, 2013 11:21 am
by ScottishPinz
Mine is attached to the existing arial tube mounts on the front, but it is only the bar of the jack, the rest is stored inside.
