LED flood lights and mount
norcal pinz
Post by norcal pinz »
Image Image Image Image
710M 1972
710k 1974
norcal pinz
Re: LED flood lights and mount
710M 1972
710k 1974
Good looking mount and there is still room for a camera set up. How did you do the electrical?
norcal pinz
connected it to the big red wire behind the dash ,24V toggle,then grounded it to the body in the cab.
710M 1972
710k 1974
GenevaPinz
Post by GenevaPinz »
Norcal, I will post pictures of my own LED lights mount as it answers a question of yours (here: http://www.real4x4forums.com/PinzgauerB ... f=9&t=8041).
As a picture is worth a thousand words, I will save myself some typing:
The mount is held in place by the bolts that hold the windshield hinges:
The little markers are here as a replacement for the parking lights, which I lost when I switched to Trucklite LED headlights. All wires go through the hole for the top bolt (passenger side) originally used to keep in place the antenna mast holders (which you used to mount your lights).
The LED bar is a Rigid Industries 50" bar, SR (Single Row) series.
I need to finish fabricating brackets to hold the light bar in place, the stock ones are too short and the windshield washer squirts the bottom of the light bar...
Jan
'72 Pinzgauer 710M
compunerdy
Post by compunerdy »
I like it..
Tim
1975 710K
Wow that is nice!
Where did you source the three pronged hole bolts? Not really sure what they are called.
Those look like a very secure way to keep the light bar on your vehicle.
krick3tt wrote:Where did you source the three pronged hole bolts? Not really sure what they are called.
I'm also curious about the fasteners you used. I've found drilled head machine screws with 2 holes at Amazon ( http://www.amazon.com/dp/B00DD41CVG/ref=biss_dp_sa1 )
but I've never seen the 3 hole type.
GenevaPinz
It was a bit of a treasure hunt to find tamper-proof bolts in the right diameter and length, and for once I found a supplier on my side of the pond, in France: http://www.vis-antivandale.com/2-vis-antivol-metaux
They are not very well stocked, the prices are quite steep (even though I steered well clear of the titanium bolts) and they have an order minimum of EUR 50.00, but I ended up buying a few with the matching three-pronged bits.
While searching I found a few other suppliers in the UK or the US, but it was either sale in bulk by box of 100, or they did not have the right dimensions in metric.
Making it more than a 30-second job to take the mount or the light apart is definitely a good thing, these LED bars are not exactly given.
Jan
'72 Pinzgauer 710M
totaljoint
Post by totaljoint »
Now, to find the matching driver!
