D rings on front. How are they mounted?
- audiocontr
How are the DRings mounted?? Are they welded?
Re: D rings on front. How are they mounted?
Look to be welded. I see no bolts and I think I see a weld line at the edges of the brackets.
Would not be my cup of tea, each to his own.
- drings.jpg (15.08 KiB) Viewed 4027 times
Looks like they are welded.
A delusional mind is what you make of it...
That's only, what, 10 or 8 gauge steel that its welded to? Could be dangerous.
- audiocontr
My guess is for trailering. It would be handy for quick tie down scenarios
Still not much strength for the constant beating they would take as tie downs.audiocontr wrote:My guess is for trailering. It would be handy for quick tie down scenarios
Guys: The PO did this. They do not look like they have ever been used by the PO either. I have never used them nor do I intend to. They are a joke I will eventually remove them.
Regards, Kevin
'73 710K sold 01/22/2016
I knew I’d seen those before.
I’ve seen a number of interesting modifications done by PO on other trucks too. I think we should find out where TP his house.
