Simple Rear Step for those with a standard 2" Hitch.
milesdzyn
Post by milesdzyn »
I made this to keep the rear step as simple as possible with no moving parts or springs.
Construction is of 2" square tube and a short piece of 3"x1.5" rectangle tube.
All the ends have been capped off and there is a locking pin. The raised diamond grate is great for a sure footed grip, just big enough for one foot.
There is a second locking position that blocks the door from being opened, just an added security feature for free while getting the step up for running the trails.
Has been working great and easily supports my 240 lbs. with no problems.
Miles
'73 Pinzgauer 712M
Re: Simple Rear Step for those with a standard 2" Hitch.
Very nice! A clean and simple design.
You should consider making them for sale. Any interest?
Pinz710m2
Post by Pinz710m2 »
That is a nice, clean, professionally executed design.
Nice job.
milesdzyn
Post by milesdzyn »
pcolette wrote:Very nice! A clean and simple design.
I have no interest in making these as there are to many variables to make them fit all applications. My hitch is shorter than the others I have seen made, as I did not want to extend it out past the body.
I don't claim ownership of this design or concept.
If I had a tube bender I would have bent the 2" square tube instead of notching it and also a simple u channel would have been strong enough for the step platform. I tend to over engineer things.
Miles
'73 Pinzgauer 712M
Thanks for posting your step. It is a very good job and looks to be following along with the quality work you do.
