Installed a military VHF antenna on the 712M
Dr-Nuts
Post by Dr-Nuts »
Found an military NOS VHF antenna locally and then picked up a Humvee mount and installed them n the pinz. The antenna has a tuning switch so it works great on 27MHZ and ok on 2 Meters. Did not want to drill into the pinz body so installed it on the heater cover. What do you think?
Mark
A delusional mind is what you make of it...
Re: Installed a military VHF antenna on the 712M
Nice mounting job! It looks really good at that spot. I bought one of those antennas years ago - I may finally get around to installing it.
Is that the one piece front bumper with guard that SAV was selling?
'73 Swiss 710M
Dr-Nuts
Post by Dr-Nuts »
Yes on the bumper. Wanted a little bit more protection from an off center impact. Probably wishful thinking but it is a much stronger bumper then the stock unit. The brush guard was from SAV and it is a real pinz unit designed for jungle terrain as I recall.
The Humvee sugar scoop bracket is smaller then most of the others out there and fit nicely onto our heater cover. Tried to make the antenna and bracket look as stock as possible.
Mark
Looks good, I always like modifications that don't require new holes.
What part of the world are you in?
Dr-Nuts
Post by Dr-Nuts »
I reside in the peoples republic of Massachusetts.
Mark
GenevaPinz
Post by GenevaPinz »
Nice, clean install!
Did you avoid the factory antenna location (mount in the middle of the front roll bar) to avoid issues with overall height? Because it is just an exercise of bolt the plug off - bolt on the antenna base, and wires remain inside the front cab.
Jan
'72 Pinzgauer 710M
bonefish635
Post by bonefish635 »
Looks great.
You might have this covered (I can't make it out on the pics), but those spring mounts allow huge lateral play in an aerial. On the K bodies there are two guy lines per side, to control the movement of the aerial. You might find that just one, vertical, guy line allows it to sway out to the side too much for everyday driving. Bound to be an easy fix though.
Tony
1973 710K
2001 Landcruiser Amazon
2007 Range Rover Vogue (sold)
Dr-Nuts
Post by Dr-Nuts »
The Pinz Barely fits into the garage so much so that we had to remove the antenna base from on top of the cab and replace it with a flat plate.
When driving the antenna is secured at about 45 degrees like in one of the pics and after a two hour drive last week on the highway the antenna did not have any issues. I also thought this may have been a problem with a single guy-wire but so far it turned out to be a non issue.
Mark
How far out from the rub rail does this protrude?
Dr-Nuts
Post by Dr-Nuts »
I would say maybe 2 1/2-3" but for sure it is well inside the side mirror protrusion.
Mark
