View unanswered posts | View active topics It is currently Sun Feb 25, 2018 1:32 am
Reply to topic  [ 5 posts ]
 Alignment
Author Message
Post Alignment
Hello,
I'm a bit confused about how to properly adjust my TGB alignment...anyone have a good grasp of it?
Sat Sep 23, 2017 10:41 am
Profile
Post Re: Alignment
Toe-in only?...what about excessive camber?
Sun Sep 24, 2017 12:52 am
Profile
Post Re: Alignment
If you have (negative?) camber on a straight axle like that you may have some serious issues. I'd start with worn bearings/bushings or maybe something got bent from being dropped out of a plane. ?
I'll have to look at the manual for the toe specs but its pretty straight forward and you might do just as well by using one of the old methods, or take it to an old-school tire shop and let them set it up. This can be just as accurate as anything else: https://www.youtube.com/watch?v=3QuuE3siR0c
_________________
Real 4x4 Facebook: https://www.facebook.com/real4x4s
Sun Sep 24, 2017 1:46 am
Profile WWW
Post Re: Alignment
Thank you Vince, you're always a wealth of knowledge...I'm getting excessive outer shoulder wear on my tires, assumed it was out of alignment somehow...I'll get my toe-in dialed and check bearings...
Sun Sep 24, 2017 2:45 am
Profile
Post Re: Alignment
If its on both outer edges of a tire you could be simply under inflated. Is it "feathered" wear at all? Could also be partially shock related if they are worn badly, along with toe maybe.
If you jack up the tire a little and try to pull on the bottom and push on the top, and vice-versa, that should tell you if you have worn parts. It should not move at all.
_________________
Sun Sep 24, 2017 6:22 pm
Profile WWW
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
