Flamethrower coil for 123ignition
Posted: Mon Apr 03, 2017 8:52 am
by ranicotra
Can anybody tell me the best coil to match up with the 123ignition I have on the way ? The outputs and resistance vary.
Re: Flamethrower coil for 123ignition
Posted: Sun May 21, 2017 11:39 pm
by dokatd
I'm running the stock coil with my 123dist.
Posted: Sat May 27, 2017 2:23 pm
by Klug
So am I.
Posted: Tue Jan 30, 2018 8:16 am
by m15256
i understood from a US supplier that the 123 ignition was only available in 12 volts. How can the stock 24 volt Bosch coil work?
Thanks for any input on the subject.
Rick
Posted: Tue Jan 30, 2018 5:10 pm
by mopar
I believe 50,000 (just example not sure what the volvo output is)volts coil output is the same indifferent if the system is 12v or 24v. That why guys are uing bosch superbeatle(12v) on the pinz(24v) at least thats my understanding. I think you just need a 12V source for the distributor to signal not the coil That how my TGB1111 was set up. Figured all this when I died and was getting no spark because my 24 to 12v converter died.
Posted: Tue Jan 30, 2018 7:25 pm
Jim provides some insight concerning coils in this thread
viewtopic.php?f=12&t=6538&hilit=jim+24v+12v+coil
