c 306 power take off seal
Justin Case
Post by Justin Case » Sat Dec 02, 2017 8:16 pm
I am looking for a power take off oil seal for a c306 volvo. It's the seal seal for the rear axle drive line. I have tried cross referencing volvo part numbers with no luck. I was hoping someone has found a seal that works. Thanks for any help
Jim Molloy
Re: c 306 power take off seal
Post by Jim Molloy » Mon Dec 04, 2017 6:48 pm
Justin Case,
I typed both "Volvo 948635" and "Volvo 944050" into Google and found both seals available from several different sources. I did no further exploration but would not be surprised of one or more sources provide the metric dimensions as well.
Hope this helps.
Jim Molloy
Waldersee Farm
Justin Case
Post by Justin Case » Mon Dec 04, 2017 7:04 pm
Thank you, I tried cross referencing parts numbers through four of my local auto parts houses with no luck. When I searched online I typed volvo oil seal #, instead of the direct number.
