tgb Fuel Pressue
Posted: Sun Apr 01, 2018 10:37 am
I searched through the data base looking for comments about C303 fuel issues. Maybe the answer to the following is in there but I couldn't find it. In the front of the engine compartment is a fuel filter element and bowl. The top is marked pressure regulator. Acorn nut on top. Tatanka lists it as a filter (642392). Is it actually a fuel pressure regulator? If so what is it supposed to be adjusted to and how do you adjust it?
My parts catalog shows a filter (642392) in that location but the drawing shows a different style body. (no acorn nut)
The VOLVO Group 23 Service Manual that I can find on line shows a totally different filter set up with a ceramic element. It does not mention a pressure regulator.
My truck generally starts and runs OK, but won't start when the engine is hot until it cools down a little.
Thanks for any insights.
Rick
Rick
