Flange Leak
Posted: Sat Dec 21, 2019 11:02 am
by Uli-RT
Hello everybody,
should anyone have problems with flange leaks,
there is a solution at SKF.
greetings
Uli
Re: Flange Leak
Posted: Sun Dec 22, 2019 5:58 pm
by Jim Molloy
Uli,
Thank your for the reminder. Do you have the SKF part number? The dimensions? The cost? Do you plan to use the same size seal or one with a slightly larger internal diameter? Was the sleeve a simple press fit or did you heat the sleeve/chill the stub axle prior to installation.
Jim Molloy
Waldersee Farm
Re: Flange Leak
Posted: Tue Dec 24, 2019 3:37 am
by Uli-RT
Hello Jim,
I bought a complete set for € 40. The shaft seal has the original size. The repair sleeve is very thin. Installation tool is included. Takes a few minutes. Very easy to assemble. Under no circumstances make it hot.
The parts are available from Claas (Friese in the C303.de Forum) in Germany. Not easy to get.
greetings
Uli
Re: Flange Leak
Posted: Tue Dec 24, 2019 9:02 pm
by Jim Molloy
Hi Uli,
Thank you for the information.
Take care.
Jim
