C30x transmission length?
xtremexj
Post by xtremexj »
Just wondering if someone has easy access to a tranny to measure the length from the front of the bellhousing to the transfer case mounting surface. Thanks.
xtremexj
Re: C30x transmission length?
Post by xtremexj »
Anyone? With the wealth of knowledge on this board somebody must know.
I'll get a measurement tommorrow.
Exactly 40cm from front of bell housing to transfer case mating surface :wink:
xtremexj
Post by xtremexj »
Jim LaGuardia wrote:Exactly 40cm from front of bell housing to transfer case mating surface :wink:
Thanks Jim! Just doing some research and that helps me out. :mrgreen: They sure are short trannys aren't they.
Bell housing is 15cm, trans is 25mm from front mating surface to the transfer case mounting surface. Standard ZF gearbox size for that era.
