I just got my 1111 this week, and wanted to change out the coolant. I know there is an expansion tank to top off, but is it used to fill an empty system? I removed the panel over the diff locks and the small horizontal plate only to see a "cap" with a bolt in it, with a warning of "DO NOT REMOVE SEE MANUAL". Nowhere in the service or owners manual could I find a real answer to my question. It seems it would take a while to fill it via the expansion tank (?)
Also, does anyone know the capacity of the system? (couldn't find that either)
Many thanks in advance.
Kevin
Cooling system help on a TGB 1111
- muttandjeeps
1990 Puch "G"
1971 710K (moved to Mass)
1975 710M (moved to VA)
1975 TGB 1111 x2
1980 Unimog U1300
1975 TGB 1111 x2
1980 Unimog U1300
Re: Cooling system help on a TGB 1111
Just get a pinz and then you won't have to worry about a cooling system!!!
JK
This thread is worthless without pics
JK
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Now a real answer. The cap on the rad is the main fill area,then fill the pressure tank. On a side note,when I had my rad built I had a pressure cap neck installed. The press tank is now an overflow tank and I vented the cap. I really did not like the idea of a 35yr-old plastic tank w/hot water under pressure that close to a passengers feet!
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
- muttandjeeps
Mark, thanks for the real answer! The only thing throwing me off was the warning on the cap, if I do ever run in to the need to change the radiator, that sounds like a good idea! The old coolant didn't look so bad coming out, but it is changed and good to go for a while! Here are a couple pictures of "Hilda" with new tires installed today. Thanks!
- IMG00169-20110826-1640.jpg (28.44 KiB) Viewed 3277 times
- IMG00168-20110826-1640.jpg (32.35 KiB) Viewed 3277 times
- IMG00167-20110826-1639.jpg (31.84 KiB) Viewed 3277 times
1990 Puch "G"
1975 TGB 1111 x2
1980 Unimog U1300
1975 TGB 1111 x2
1980 Unimog U1300
Nice!
68 Haffy
68 Haffy
Damn nice little unit.
I like but the polis here would pull you over for the paint job
put some videos up of it offroad - or a link to youtube action please.
