C303 engine removal/rebuild
I am currently removing the engine from Greg's C303.
I finally got the EFI dialed in only for the bottom end to start knocking and losing oil pressure at idle when warm.
I suspect to find a few badly worn cam lobes when I get it out as well as worn rod bearings.
Right now , the trans and transfer case are out and I am working on pulling the head off as the engine comes out the bottom
I will post some pictures soon.......................
Re: C303 engine removal/rebuild
Sounds like it's breaking faster than you can fix it! Bound to be a strong runner when you're done.
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
We can only pray
Greg
Greg
HafWit
Greg,at least you have your avatar to look at in case you forget how it looks!
Mark
Mark
68 Haffy
68 Haffy
Mark,
That is cold. I still have my Haflingers to keep me busy. I also have a 4Runner Trail Edition that is quite capable offroad and serves as my daily driver.
Greg
Greg
HafWit
Didn't mean to be mean! Just a little jealous as your truck will be a very strong runner when its done!
Mark
Mark
68 Haffy
68 Haffy
Mark,
Your positivity is encouraging. Hopefully Dave won't rain on my parade .
Greg
Greg
HafWit
I hate it when you fix something and another part lets go . Hope you get it fixed and running soon. I suspect yours will be up and running again before mine
The engine is out , and according to Jim, the cam and 4 lifters failed . Cyls # 1,2,3, and 6 intake lobes/lifters failed due to metal fatigue .
Everything looks rebuildable .
Greg
Greg
HafWit
Here is what an empty engine bay looks like.
And here is a couple of the bad lifters.
And a shot of the trans/transfer case.
What would cause that to happen??
Vince,
That's an easy one. Obviously Gremlins!!!
Greg
Greg
HafWit
According to my Volvo parts expert, cam and lifter failure is very common with this engine type. I would suspect high milage/overheat (had bad water pump for a long time) had a hand in the failure.
I'll put some cam pics up later.
more pics.
All 4 of the really bad lifters.
flat lobes
Front of engine with timing gears exposed.
flat lobes
I guess in the past someone just kept on adjusting until the noise went away! :idea: Are there any performance cams available?
Mark
Mark
68 Haffy
68 Haffy
