View unanswered posts | View active topics It is currently Sun Feb 25, 2018 1:33 am
Reply to topic  [ 7 posts ]
 Handbrake adjustment
Author Message
Post Handbrake adjustment
There was an earlier post about the handbrake, which I could relate to. Mine didn't want to hold, and the thought of tearing it down for an inspection wasn't appealing. So I got out the maunal to see what the proceedure was for agjustment.
The manual said the handle should pull out about 90-100mm for engagement, let's call it 4 inches. The brake lever at the rear of the vehicle has a pin which connects the cable, this pin should also travel the SAME distance, 4 inches. I measured mine and they weren't even close.
I pulled the handle out 4 inches and used that as my default setting, this measurement could not change. I taped the ruler to the handle so you can see the distance easier.
Underneath the Pinz I noted the position of the pin in the retracted position.
Then I measured the position of the pin in relation to the retracted position. Here I show the same 4 inches which is correct (after all adjustments). If it is not the same, remove the pin and adjust the cable so the pin travel is 4 inches. You won't get it right the first time or the second. Each time you think you have it right, adjust the brake nut on the opposite side so the brake is fully engaged.
The brake nut is very sensitive to adjustments, 90 degrees of rotation can make a big difference, so you may have to go back and re-adjust the cable length again either way when completed. Check the handbrake by positioning the Pinz on a hill and see if it rolls, don't use the clutch to test it. You will have to go through this proceedure several times before you get it right, and when you do the brake will be like new, unless the discs are junk. The last thing you do it pre-tension the cable by twisting it 2-3 times (clockwise, facing the front of the vehicle), this takes the slack out but doesn't affect adjustment.
Fri Sep 04, 2009 4:18 pm
Profile
Post thanks
:D good job on the write up... I printed and will check mine next time I get to it..... it holds the pinz fine, but will check the measurements at least..
_________________
Pinzing is AWESOME.
Fri Sep 04, 2009 11:03 pm
Profile YIM
Post
Thanks for the detailed write-up with photos! I've added it to my archives for future reference.
_________________
'72 Swiss 710M
Sat Sep 05, 2009 6:56 am
Profile
Post Re: Handbrake adjustment
This one as well?
_________________
Real 4x4 Facebook: https://www.facebook.com/real4x4s
Fri Sep 22, 2017 3:15 pm
Profile WWW
If the photobucket account is public, we can grab the full resolution images... This one is private. And with the proper search string, I can get the image location... like for this
use the topic, followed by the site, then click on the images tab of google. ... "Handbrake adjustment site:http://real4x4forums.com"
_________________
1971 710K S
N2PNZ
Fri Sep 22, 2017 7:38 pm
Profile
I did a google search the site's address and put in, for example, DSC06379.jpg which is one of the original pic names, but all I can find is a small, fuzzy 320pxl photo. I didnt think they were that small originally. ?
_________________
Sat Sep 23, 2017 1:45 am
Profile WWW
You are correct! The actual images are much bigger. The image that google was allowed to index has been reduced by photo*ucket. If the photobucket account is "public" than you can drill down to the actual image. In this case the account for "rmf1958" is set as "private". So, we cannot drill into the user's folder.
As you noticed, this is a painfully slow process due to all the popup ads.
_________________
1971 710K S
N2PNZ
Sun Sep 24, 2017 12:16 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
