How do you remove the Dynastart fan?
Posted: Sat Sep 20, 2014 7:04 am
by Heinkeljb
I would like to take the fan off the Dynastart so i can clean and paint it whilst I check on the brushes. I know it is locked to the shaft with a key / keyway to make it rotate with the shaft. I don't think you can get a puller on it as the fan blades overlap.
So how do you take it off?
Regards,
John
Re: How do you remove the Dynastart fan?
Posted: Sat Sep 20, 2014 1:53 pm
Mine just came off once I got the nut off
Posted: Sat Sep 20, 2014 5:47 pm
by Heinkeljb
How long has it been on the Dynastart? Mine is likely to have been on the shaft since 1983!
Jim has put forward an official method - Use a puller that screws down the center of the fan. Or a system that uses the weight of the Dynastart along with a hammer and drift to tap the shaft down through the fan.
I'll take the Dynastart off and have a good look at things on the bench.
John
Posted: Sat Sep 20, 2014 8:22 pm
Sounds good
I am not sure how long mine was on for as I have only owned it for 3 years
Guess I was lucky (to bad there are 100 other parts of the Hafi that I was not lucky with)
Heinkeljb wrote:How long has it been on the Dynastart? Mine is likely to have been on the shaft since 1983!
John
Posted: Mon Sep 22, 2014 9:56 am
by westernair
I sprayed mine with a penatrant, then just grabbed the shroud and shook it up and down letting the weight of the dynastart act as a slide hammer until it came off took maybe 10 min. Make sure you put some grease on the shaft before reassembly so it doesnt happen again.
