8 July 2017
So early morning drive to IPOH 190k gone. Breakfast then down to the workshop. Hmmmmm not open So I go to the bearing shop instead. Now the workshop going to be is open so I head to the workshop after getting bolts for the bearings for the testing of the rollerdrawer design. I also drop the TURBO of my RED monster in for surgery to make it spool up faster since the RED monsters engine is getting a head overhaul due to pitted intake valves sigh and an overheating issue. IPOH has an excellent diesel performance tuning shop.
The progress is explained to me so I can carry on with my plan while they do the wiring in the next 2 weeks
Finish the doors and cockpit metal fabrication.
I hand over the new simple shocks I have purchased. They can be installed anytime not today.
I have the doors to panel up. The kneepads to remake and the speaker panels to prepare to bend and paint and bolt in.
The test bearings to get the measurements from for the roller drawers we will need 50-60 of these. Now I can finish the drawing ready to get CNC cut.
First the newly covered new seats. They look cool and will not be as sweaty as the PU.
The mess I have to start with - a door and the really rusted knee pads from Volvo 2 as samples. My goal is to finish paper templates and then do the cutting. WHo needs a huge crew like overhauling I can do all this myself.
Soon I have left door top panel done. The right well I prepared it and fited it but with 20mm left to slide in it will not budge. I need to knock out and do some trimming and and sanding with the flapper wheel. If the 5 bar plate proves to be too rough on the skin then I will replace with smooth panel. They are almost ready to get powder coated or anodized.
Door templates done. I could not do the cutting as I had trouble getting the 84 sheet to stay steady by myself so have left the big chop for the shop to do for me.
Next the afternoon killer the kneepads. Takes me several hours to get them cut out. The drivers side proving to be a pain to cut and will be a pain to fit due to the power steering and the new brake cylinder. I can make these out of 1.6mm steel next visit. Next is to find the sponge - im looking at kiddy playground floor sponge then I can shape it and cover them in Vinyl and fit.
Speaker panels need sanding after the lazer cut has left a lot of slag. I have 3 spots to get a fine file in and cleanup then they are ready for bending. Alloy bending template left for the workshop to bend them.
The front swithc panel is all cut out os stainless steel. I have requested it be cleaned up and clear coated. Connecting of the panel wiring and switches starts this week.
Wiring diagram has been revisited and some 24v stuff converted to 12v including the air conditioning. Only the starter and the t-Max winch remain 24v.
Service hatches have now been cut to allow generator and fuel pump access.
Final pic before I head off home. It hasn't changed much but quite a bit of work done.
Home time for the long drive home. Sicne they have added new speed cameras in the past month I have slowed down a lot and happily sit on 110kph.
Plans for the rollout drawer and the 2 slide out tables - cooking and eating are almost complete soon can start the CNC drawings and the building of the drawers and tables in KL.
![Image](http://www.geckoadventure.net/Volvo/20170709_094319.jpg)
