Oil, air and fuel filters
Posted: Sat Jul 01, 2006 10:19 am
by Ugo
Hi all,
What are the correct references for the oil, air and fuel filters?
Ugo
1977 710K
1990 716K
Torino, Italy
Posted: Sat Jul 01, 2006 1:05 pm
by The true Pinzgauer´s
Hello UGO
first why don´t you buy a spare part list from Magna or Verwüster?
Oil filter brand: MANN No:W 950/4
Air filter brand: MANN No:C 15 165/3
Fuel filter are 4 different typs also water-seperator´s which do you have ?! send me a picture of it , than i can tell you which is fitting.
If you need a crossover list, tell me too.
Posted: Sat Jul 01, 2006 7:11 pm
by Profpinz
G'Day Ugo,
The easiest way to find them is on the Rocky Mountain Moggers site.
http://www.rockymountainmoggers.com/pin ... parts.html.
If the page doesn't come up directly, go to: Pinzgauers, then Part Numbers.
Regards,
Posted: Mon Jul 03, 2006 11:31 am
by Ugo
Thanks for answering!
The true Pinzgauer´s: Yes I do have the spare part list from Magna, but it gives only the Magna Steyr codes (i.e. 716.xx.xxx.xxxx) while I need the commercial references.
Profpinz: the link you mentiond leads to the 710/712 part numbers; my Pinz is a TD. Or am I missing the right link?
Regards,
Ugo
Posted: Sun Jul 16, 2006 8:41 am
Hello UGO ,Hello TD owners
now i have time to sell you the cross referece list of TD Filters.Even care has been taken in compliling this lists, however no warrenty is given for the detail provided. All number identifikations are from SF,Knecht,Hengst and Mann - Filter manufakturs cross-over ( cross-referece) lists. No warrenty for exact fitting of all named filter types.
Bosch,Fleetguard,Hengst,Knecht and Mann ( original Typ) are tested and the fitted.
AirFilter SDP 716.1.19.502.2
AC: PC 177
Air Refiner : ARM 1553
Baldwin: PA 2767
Cooper: AZA 129
Crosland: 9561
Digoema: DGM 01128
Donaldson: P14-0186 and P18-1089
Fiaam: FLI 6459
Filtrel:823-FV
Fleetguard: AF 4135
Fram : CA 3295
Hengst: E 113L
Hirschi: SA 14085
Knecht/Mahle: LX 275
Mann: C 15 165/3
Motorcraft: EFA 304
Purflux : A801
Purolator: PM 1762 and A67762
SF-filter: SL 6212
Technocar: A 494
U.F.I.: 27.828.00
Woodgate : WGA 128
Filter most build in/ main applicationed : Volkswagen
OilFilter SDP and VW 075 115 561
Alco: SP 958
Bosch . 0 451 203 087
Champ LS 123
Coopers: Z865
Fram : PH 2964 and PH 4854
Hengst . H19w06
Kayser: Ak 14-D
Knecht/ Mahle: OC 105
Kolbenschmidt: 165-05
Mann : W 950/4
PBR: BC 1043
Purflux LS 553C and LS 186
Purolator L 40316
Technocar: R 240
SF-Filter: SP 4415
U.F.I. : 23.156.02
Filter most build in : Volkswagen,Volvo
Fuelfilter 2. version ( most mounted) SDP and VW 191 127 401C
from Enginenr NY 001609
AC: XD 67and XD77
Alco: SP 966
Bosch 0450 670 189, 1 457 434 endings 094, 099,101,105,106,107,110
113,121,150,156,158,159,425
CAV: 7111/496, 7176/491, 7176/496A
Champ FS 50
Champion: L111, L112,L133
Coopers: AZ F 090
Crosland 5006
Donaldson: P 55-0152, P55-0587, P55-4620, P77-9376
Fiaam: FP 4937A, FP 5248,FP 4935,FP 4935A,FP 4936,FP 4685
Fleetguard: FF215,FF231,FF 5060,FF 5135,LF739, FS 1221,FS1251
Fram: P3522,P4183,PH 52
Hengst: H70WK02
Knecht/ Mahle: KC8, KC18, KC 32, KC 35 , KC38, KC43
Kolbenschmidt: 075-FS
Laurette: ELG 5214
Luberfiner:LFF3504, LFF3506
LUCAS:HDF 496
Mann WK 842/2
Motorcraft: EFG 48, EFG 57
Purflux: CS 183,CS 197, CS197A,CS 197B, CS 412,CS 412B
Purolator: F5722248,PER 151-F,PER248-F
Savara:SN 468, 9.28.327, 9.28.468
SF-Filter SK 3820
Technocar: RN 110B, RN 182B, RN 11B
U.F.I.:24.351.00, 24.355.00,24.355.01. 24.377.00
WIX (USA): 33372
Filter most build in : AlfaRomeo,ARO,AUDI,Dacia,Fiat,Ford(eu) ,Lancia,Opel
Renault,Rover,Seat,Vauxhall,Volvo,Volkswagen
I hope help someone with my List
Grettings from Germany,W.Fuss
Posted: Thu Jul 20, 2006 7:52 am
by Ugo
THANK YOU for this very useful information!
Best regards from Italy,
Ugo
Re: Oil, air and fuel filters
Posted: Mon Oct 14, 2013 7:55 pm
by mopar
Just did some maintenance
and For the US 718 folk local NAPA Parts are
Oil Filter is Napa 1773
Fuel Filter is Napa 3472 screw on type
Air filter is NAPA 2523
