Wedge for removal of halfaxle
Posted: Mon Jan 08, 2007 6:38 am
by aparg
Hi,
could anybody provide the dimensions of that tool. Looks like it could be build without to much effort.
Many Thanks
aparg
Posted: Fri Jan 12, 2007 3:19 pm
by Tads
We've got one somewhere - I'll some dims for you
Tom
Posted: Sat Jan 27, 2007 3:50 am
by Tads
Aparg,
The complete axle puller is still available from Magna Steyr - part number 9053334042 with the excellent description "pulling-off device"!
If you still want dims of the wedge I'll try and produce a drawing for you sometime next week.
Tom
Posted: Mon Jan 29, 2007 2:17 am
by aparg
Hi,
many thanks for your efforts already. I do indeed prefer the dimensions. I assume that it will be helpfull to quite a hand full of people, since buying the part would make no sense for e.g. one axle cuff.
Many Thanks in advance.
Posted: Fri Feb 02, 2007 10:28 am
by Tads
Hi Aparg,
I've finished modelling the wedge - do you have access to any kind of CAD? If so, tell me what format and I can send you the info now. If not, I'll do a drawing for you to take to a machinist. One word of warning, the wedge I've got is machined from a pretty large billet and will probably cost a fair amount to get made. I could redesign it in two parts but this will be going away from the original - what would you prefer?
Tom
Posted: Tue Feb 06, 2007 3:17 am
by aparg
Hi,
many thanks. Unfortunatelly I dont have access to a CAD system. I could open jpeg and pdf if that is of any help to you. You dont need to make any changes to the original. Many Thanks for your efforts
Best regards
aparg
Posted: Tue Feb 06, 2007 9:01 am
by PinzEOD
The three times I've needed one, a 1/2" wide cold chisel works great as a wedge, assuming that particular bit of housing separation is the same as for the old Pinz.
Posted: Fri Mar 09, 2007 3:44 am
by aparg
Thanks for the hint.
However my right thumb would prefer the proper tool in the future. It worked but was quite an act. Therfore if anybody could provide me with the infos I would be very pleased.
Posted: Sun Mar 11, 2007 4:21 pm
by Tads
Aparg,
You have PM
Tom
