716 Pinzgauer Front shocks
Posted: Tue Nov 13, 2007 1:03 pm
by dumptruckGB
Got a 716K and the front shocks need to be replaced , anybody got any good suggestions what make of shock can be used , other than the original and going to Steyr ..Thanks
Posted: Fri Nov 23, 2007 11:06 am
by Tads
Don't have any recommendations for you but I can get you some basic data so that can hunt around for something suitable.
If you want to stick with the standard part the part number and original supplier are stamped on the damper...
Tom
Posted: Sat Nov 24, 2007 2:38 am
by dumptruckGB
That would be a great help , thanks .
Posted: Tue Nov 27, 2007 2:25 am
by Tads
Okay, basic data:
Compressed length: 376mm
Extended length: 526mm
Damper body dia: 55mm
Damper shroud dia: 64mm
Damper end type (both ends): 16mm int dia tube, 26mm ext dia, 54mm long
The damper has a combined mechanical/hydraulic rebound stop. Sorry can't give you damper performance data.
Posted: Thu Nov 29, 2007 4:42 pm
by dumptruckGB
Good stuff , thanks .
