TD trans capacity
Anything DIESEL driveline, axle, suspension related goes here.
M Wehrman
TD trans capacity
Post by M Wehrman »
Well I looked for obvious postings for this info and I know I read it on the forum. I also know I may get the evil eye :lol: from Dunn for not looking . :( I also figure Eric will find it and put in a link,as he has an uncanny way of finding this stuff,kinda like the Real forum's bloodhound :D I'm only blind in one eye,just can't see out of the other.....
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Welllllllllll, if you go by TD manual... it takes 7.0l, including the oil filter. BUT , I don't think you're talking about an autobox. :wink: :lol:
The manual gearbox takes 2.0l.... and if that is any different than the standard 710/12 trans, I'd be shocked :shock: ... it's the same case. Of course it could hold more oil if tilted to the left, than the right :?
Vince, insert Big cyclop eye here X
:D
What does ya know? I was right.... ran across the manual for one of them there old Pinz's with sparkling plugs and the gearbox held 2.0l also. :wink: :lol:
M Wehrman
Post by M Wehrman »
On a past post someone said the TD box held less lube. Thanks David for the clarififation.
Mark
68 Haffy
Erik712m
Post by Erik712m »
M Wehrman wrote:On a past post someone said the TD box held less lube. Thanks David for the clarififation.
Mark
:oops: That would be me. :oops
I had Confused one of Jim's post.
They tend to burn up quicker when you run them low on oil due to the steep ratio's
twenty some thousand post things start to run together at times.
And Dave before you post I would just like to say Image
I found smileys. :lol: :lol: :oops: :oops:
I'm proud of you Erik... you finally got that booger off your finger.
Did you eat that one too? :D
Erik712m
Post by Erik712m »
Taste like chicken?
M Wehrman
Post by M Wehrman »
I...I...Am so confused....Thanks,...but maybe not,....I must believe in something :? ...so another beer it is! :D :D
68 Haffy
M Wehrman
Post by M Wehrman »
Urp!..On a side note,..I am sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo disappointed in you Eric! :x :x
68 Haffy
M Wehrman
Post by M Wehrman »
Eric,
Perhaps you may redeem yourself and share your new emotiocons ( whatever,the smiley guys w/attiudes are called) with me.Then we can BOTH bless the community! :P
Mark
68 Haffy
Erik712m
Post by Erik712m »
M Wehrman wrote:Eric,
Mark
Here you go. http://www.freesmileys.org/smileys.php
