TD trans capacity
Posted: Mon Sep 14, 2009 7:48 pm
by M Wehrman
Well I looked for obvious postings for this info and I know I read it on the forum. I also know I may get the evil eye
from Dunn for not looking .
I also figure Eric will find it and put in a link,as he has an uncanny way of finding this stuff,kinda like the Real forum's bloodhound
I'm only blind in one eye,just can't see out of the other.....
Mark
Posted: Mon Sep 14, 2009 8:35 pm
by David Dunn
Welllllllllll, if you go by TD manual... it takes 7.0l, including the oil filter. BUT , I don't think you're talking about an autobox.
The manual gearbox takes 2.0l.... and if that is any different than the standard 710/12 trans, I'd be shocked
... it's the same case. Of course it could hold more oil if tilted to the left, than the right
Vince, insert Big cyclop eye here X
Posted: Mon Sep 14, 2009 11:05 pm
by David Dunn
What does ya know? I was right.... ran across the manual for one of them there old Pinz's with sparkling plugs and the gearbox held 2.0l also.
Posted: Tue Sep 15, 2009 6:07 pm
by M Wehrman
On a past post someone said the TD box held less lube. Thanks David for the clarififation.
Mark
Posted: Tue Sep 15, 2009 6:59 pm
by Erik712m
M Wehrman wrote:On a past post someone said the TD box held less lube. Thanks David for the clarififation.
Mark
That would be me. :oops
I had Confused one of Jim's post.
They tend to burn up quicker when you run them low on oil due to the steep ratio's
twenty some thousand post things start to run together at times.
And Dave before you post I would just like to say
I found smileys.
Posted: Tue Sep 15, 2009 7:08 pm
by David Dunn
I'm proud of you Erik... you finally got that booger off your finger.
Did you eat that one too?
Posted: Tue Sep 15, 2009 8:38 pm
by Erik712m
Posted: Tue Sep 15, 2009 9:13 pm
by David Dunn
Taste like chicken?
Posted: Wed Sep 16, 2009 12:09 am
by M Wehrman
I...I...Am so confused....Thanks,...but maybe not,....I must believe in something
...so another beer it is!
Posted: Wed Sep 16, 2009 12:11 am
by M Wehrman
Urp!..On a side note,..I am sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo disappointed in you Eric!
Posted: Wed Sep 16, 2009 12:18 am
by M Wehrman
Eric,
Perhaps you may redeem yourself and share your new emotiocons ( whatever,the smiley guys w/attiudes are called) with me.Then we can BOTH bless the community!
Mark
Posted: Wed Sep 16, 2009 2:39 pm
by Erik712m
M Wehrman wrote:Eric,
Mark
Here you go.
http://www.freesmileys.org/smileys.php
