Trasfer case removal
Anything DIESEL driveline, axle, suspension related goes here.
Ugo
Post by Ugo »
I am having an oil leak form the transfer case on my 716k.
Should the tran. case be removed for overhaul, what sort of job shoud I be prepared to do? (or ask the repairman to do?)
Would the damn thing drop down by undoing some bolts, or is a central tube extensive disassembly work needed?
Ugo
You must support the body and remove the rear diff to remove the t-case.
Ugo
Post by Ugo »
Thanks Jum.
Ugo
