Atik G wheels
Posted: Mon Feb 04, 2013 4:04 pm
by gunipinzmutt
The most common alu rims seen on TDs are Atik from G-wagen. Are there adaptation jobs to be done? Are longer bolts needed?
Re: Atik G wheels
Posted: Sat Feb 09, 2013 12:36 am
by ExpeditionImports
We are using a wheel on our tour conversions that is made in the UK for the Sprinter vans. They are relatively inexpensive, look good and are pretty much a bolt on conversion. You will have to change out the wheel studs to a Conical Lugbolt, we found the correct ones in Italy! Retail price in the U.S. is about $175 a wheel and $2 a lug bolt.
Scott
Re: Atik G wheels
Posted: Sun Apr 14, 2013 4:28 am
by fesm_ndt
G Wagen rims fit if you ream out the mounting holes.
I cant recall how much but doable
Porsche ones don't fit as the central hub bore was too small. I just happened to get some Porsche rims to play with one day
Re: Atik G wheels
Posted: Thu May 26, 2016 5:24 am
by VinceAtReal4x4s
I can't recall for sure but aren't the stock steel/military Gwagen wheels the same as the steel TD wheels? Like the green ones on the back of that pic?
Re: Atik G wheels
Posted: Thu May 26, 2016 5:56 am
by Profpinz
This is what Magna Steyr/Mercedes are fitting to all the Australian Military G-Wagens.
Re: Atik G wheels
Posted: Thu May 26, 2016 2:14 pm
by VinceAtReal4x4s
I like the older Euro/rest of the world military, or those newer Canadian mil. version:
Re: Atik G wheels
Posted: Fri May 27, 2016 10:15 am
by Profpinz
The Hutchinson Wheels are my all time favourites (Canadian G) but at 876 euro each (I have seen them available a little cheaper from a few specialist suppliers) I think I'II be waiting for a Tattslotto win before I buy any.
http://www.puch.at/en/spare-parts/acces ... spx?LNG=en
Re: Atik G wheels
Posted: Fri May 27, 2016 2:51 pm
Hutchinson's are great but once you go through rocks and bash up the 15 stud threads (x4 = 60) you'll be lucky to get them off without breaking them!
Some Hutchinson's come with the plastic nut caps but not a great solution.
- 5-27-2016 3-50-47 PM.png (109.72 KiB) Viewed 1916 times
