Front door glass
Pretty much anything 716 or 718 technical that is not driveline or engine related.
fesm_ndt
Front door glass
Post by fesm_ndt »
I don't see this in the book..... and I thought straightforward but how does the glass come out? :oops:
I thought the 2 screws at the top but seems fairly solid even after taking them out.
Regards
(Project Gimpy 2)
David Dunn
Post by David Dunn »
Hi Mike,
You need to remove the door top . There are 2 bolts front and rear in the edges of the door ( under rubber caps, if still there), then the top lifts off ( watch for the placements of the steel shims). Then unbolt a pair of corner brackets and slide the frame apart.... It's been over 6 years since I changed mine... I might be a bit fuzzy on the details.... or I was drinking :roll: :wink:
Cheers :D
fesm_ndt
Post by fesm_ndt »
have to check that out today. I had been attacking it from the top :cry:
Regards
(Project Gimpy 2)
