Front door glass
Posted: Mon Oct 12, 2009 2:42 am
by fesm_ndt
I don't see this in the book..... and I thought straightforward but how does the glass come out?
I thought the 2 screws at the top but seems fairly solid even after taking them out.
Posted: Mon Oct 12, 2009 9:14 am
by David Dunn
Hi Mike,
You need to remove the door top . There are 2 bolts front and rear in the edges of the door ( under rubber caps, if still there), then the top lifts off ( watch for the placements of the steel shims). Then unbolt a pair of corner brackets and slide the frame apart.... It's been over 6 years since I changed mine... I might be a bit fuzzy on the details.... or I was drinking
Posted: Mon Oct 12, 2009 8:17 pm
by fesm_ndt
have to check that out today. I had been attacking it from the top
