Don't use rubber gaskets!!
I decided to try the "upgraded" rubber gaskets on my valve covers and oil pan. DON'T DO IT!!! The OEM paper gaskets will not shift, squish out, or rot like the rubber ones will. My "upgrade" lasted about a month before all the rubber gaskets started failing left and right!
We also gave up on the rubber gaskets. They just did not seem to stay seated like the original ones. Too bad though it sure seemed like it should have worked. Maybe if there were a groove to keep them in place or tabs, something along those lines. All of the ones used here whether a tacky gasket sealer or silicone was used all failed to stay in place.
You have to make sure the mating surfaces are flat for good results when using any rubber gaskets. I have found numerous warped valve covers, a good belt sander will help repair the surface. One more tip, NEVER use silicone sealant on rubber. Brush tack or Super glue on ONE SURFACE ONLY. If you try to use sealer on both sides of a gasket it may split when tightened(hydraulic pressure) ![Shocked :shock:](./images/smilies/icon_eek.gif)
I ruined my first rubber pan gasket by overtightening. I bought another one, and was very careful to tighten in sequence while watching the gasket. Once it STARTED to squish from compression I stopped tightening and torqued all of the nuts the same with an inch-pound wrench. I found the rubber takes much less torque than the cork gasket. I drove a few miles and re-torqued slightly and everything is OK. I used nothing on any surface, such as sealer or tack. Personally I would rather use cork gaskets for low compression applications such as the pan gasket or valve covers.
Some engine oils are not compliant with certain forms of rubber... I used the SAV units on my Pinz and it doesn't leak a drop, but I did coat them with a bit of grease on both sides at the time of install..
Over torquing is a common mistake amde.. A little loose is much better than too tight, especially when the engine expands and contracts a few times.
Rubber Gaskets
I bought Scotts gaskets and have had the rocker covers on and off a couple of times to adjust the valves over the last year and a half.....
NO LEAKS!
Thomas E.
712M (soon to be 712C amper)
Sonora, CA
NO LEAKS!
Thomas E.
Sonora, CA
used to have a customer with a mobile gasket cutting service. They had a computer full of specs and several different materials and a cutter in the back of a van. You could also give them your own specs and get custom-cut gaskets for just about any application (industrial/old cars/machinery). Anyone hear about such a thing. I hear you all talking about preferring cork and having trouble with OEM, etc. Wonder if finding such a place and getting a bunch cut from the best material/splitting costs between pinz owners would be worth while or not. Anyone have any experience with such a company or know about costs. Are good gaskets that hard to come by? Is this a good idea or should i stop talking?
Dittohrafn wrote:My rubber valve cover gaskets (purchased from Scott) are still intact after a year. I glued the rubber to the valve cover with Indian Head Gasket Shellac. I had plenty of trouble keeping the OEM paper gaskets in place, even if they were glued.
Mike Newton 1973 712M (sold)
