David Dunn
Posts: 2274 Joined: Wed Apr 14, 2004 7:08 pm
Post
by David Dunn » Sun May 21, 2006 1:11 am
To be on the safe side, remove the door tops and lay them on a towel to replace the glass..... gravity is less likely to make for a bad day.
David Dunn
Post
by David Dunn » Thu Jun 01, 2006 6:15 pm
Received the first shipment of tinted door glasses today... just waiting for that first 710/12 to put them into.
Have sets for Ms and Ks.
Dave Dunn
2012
Post
by 2012 » Thu Jun 01, 2006 7:20 pm
how much?
David Dunn
Post
by David Dunn » Thu Jun 01, 2006 7:33 pm
Prices are on the previous page
David Dunn
Post
by David Dunn » Sun Jun 04, 2006 11:20 am
FORKLIFT - The other windshield removing tool!
Note- No Pinzes were hurt during the filming ..... but maybe I should have had the driver get out beforehand.
lindenengineering
Posts: 715 Joined: Sat Apr 17, 2004 6:14 pm
Post
by lindenengineering » Sun Jun 04, 2006 11:28 am
Watch out for those forks!!
Patrick at Cold War had a yard man put a set of forks through the side of a Pinz, in short squewerd! Not pretty and a bit expensive to fix.
In that incidence no-one got hurt, just some pride and pocket money!
Dennis
OOOps no customer bashing now
EvanH
Posts: 175 Joined: Wed Apr 14, 2004 4:14 pm
Post
by EvanH » Sun Jun 04, 2006 1:09 pm
Ok, Dave, if you can install one the same way l will be REALLY impressed!!!
-Evan
MarkPinz
Posts: 115 Joined: Thu Oct 28, 2004 11:21 am
Post
by MarkPinz » Sun Jun 04, 2006 3:10 pm
Even with the advanced installation technique
My K is very happy with the set of Dave's new windows
Just get in and go....
ktmkirk
Posts: 18 Joined: Thu Sep 29, 2005 10:10 pm
Post
by ktmkirk » Wed Jun 28, 2006 8:42 pm
David, Do you know or someone else on the forum know where I can get that little trim piece that goes on the edge of one of the side windows of the Pinzgauer, I received one from SAV but the other side is backordered. ANy suggestions, I am going to try some Auto trim places but I'm not sure if there is already a repalcement for this peice that is readily available...Kirk
[quote="David Dunn"]To be on the safe side, remove the door tops and lay them on a towel to replace the glass..... gravity is less likely to make for a bad day. :wink:[/quote]
David Dunn
Post
by David Dunn » Wed Jun 28, 2006 9:34 pm
Kirk
I'm not sure I understand what trim piece you're refering to. The felt tracks? Do you have the part number?
Dave Dunn
ktmkirk
Post
by ktmkirk » Wed Jun 28, 2006 9:40 pm
SAV only had one peice and the other peice is backordered it is called a seal strip ,part# 7111761681 and is the vertical peice that goes on the edge of one of the sliding windows that acts as a seal between the two windows
[quote="David Dunn"]Kirk
Dave Dunn[/quote]
