What is the most advance that a Pinz engine can run on regular unleaded gas? I thought I had read somewhere that the Pinz engine was sensitive to timing.
The reason I ask is that after installing a Pertronix module, I checked the timing. It was slightly advanced, so I adjusted the distributor back. I was only able to get it to around 5mm advanced with a warm engine (I believe the stock spec is 3mm advance with a warm engine). The engine rpm at idle correspondingly went up slightly. I'm trying to decide if I leave the timing at 5mm and adjust the carbs to give a lower idle speed or if I adjust the distributor more. The reason I didn't adjust the dizzy back more is that it seemed to be physically blocked from turning any more...I'm thinking it may have to be adjusted one tooth over.
Its all about timing...
Kimball
1979 712M
1979 712M
