Exhaust in cabin
i'm getting exhaust in MY cabin when the top is off or a window is open. so i guess it's coming from the tail pipe right there.
have any of you with the mod'd pipes that go out farther back noticed a decrease in exhaust in your cabin? and how do you guys know what the hell i'm saying with all my typing errors?
2012- Foz and I have the same kit. It came from Scott at EI. If you look at picture #3 you can see that Foz ran his through the body mount and then curve around and out. On mine we ran the pipe up into the wheel well and I have had some rubbing issues. I believe that if I had it to do again that I would go the same route as Foz. The braided steel hose is a GREAT IMPROVEMENT over the old piston ring style that came from the factory. You can just buy the hose section and not the rest of the kit. You have a brand new stainless steel pot belly muffler so I would not change it but I would change the flex to this style when (and it will) starts to leak. Since installing the EI kit I have had no exhaust in the cab.
