Teflon tape on diff, tranny, wheel, lube plugs?
Do I need to tape the plugs while I'm doing fluid changes (to avoid leaks)? I guess I'm asking will it hurt anything if I do? I've heard in other auto applications to never do this because it can get torn off inside and potentially clog lube passages.
crush washers
You can get them at NAPA, check the SDP site for the parts cross reference chart.
Morris
Morris
I put some copper AntiSeize out of a tube on them to make them easier to remove (once you get them out the 1st time). Dennis suggested this to me a long time ago!
Don't know if this helps seal them or not but I remember some of the early posts where they were stuck & the heads got stripped & they had to be drilled.
Don't want to go thru that.
