Did later Pinz's come with rubber rub rails?
Saw these pics on SAV's site. Looks like a molded rubber rail?
http://www.swissarmyvehicles.com/shpics ... m=60&cat=1
1973 712M
To my knowledge the 710/712 only came from the factory with wooden side rails.
Many "aftermarket" modifications have been made over the years but I can't say I've ever seen rubber side rails.....The G-Wagen had rubber rails!
http://www.ozpinz.com
- ScottishPinz
Can someone explain the benefit of rubber rub rails (say that three times fast)
I love the wood ones, I used it extensively last weekend, and all the "damage" to the rub rails will be fixed in about 5 minutes with some sandpaper and OD green paint. It seems to me that rubber rub rails would grab obstacles instead of sliding smoothly along them.
Yeah, I've seen that on Jeeps before. I think it's a teflon plastic or something like that. Not sure if it would take paint, though.Erik Maybee wrote:Todd do you fallow any of the other off road venues? If so have you seen the white plastic bolt peaces there putting on skid plates? allways thought it would make a nice rub rail replacement.
1973 712M
Andy I also have them on my 710. I have also built a new rear bumper, spare tire carrier and jerry can holder. The rails can be seen in use in my video on youtube http://www.youtube.com/watch?v=FZ-geO6dWNU
The metal rails are not sacraficial and hold up extremely well. I have had them on my 712 with similar use in rocks, trees and other larger obstacles. I have even been hit in the rear corner of my 712 with no damage to my truck, the other guy was not so lucky.
I still prefer a more solid side rail even though much has been discussed about softer wood rails. Of course like with all my additions and offroad armor it does not require modifying the truck and can be returned to stock.
It is all about what you want out of your truck. Personally I bought mine to wheel with.
Mike, my wood rails, what was left of them, were rotted out when I got the truck. All of the nut sert holes are rusty and I think if I use wood again, it will be a matter of time before the sun gets to the wood and then the little moisture we normally get will go to work on the truck's body.
The metal rails, I think and hope, would work better for me since I'm not so much in rock as you all are, but I have mesquite and huisache trees that reach for my truck. Your experience with other vehicles encroaching on your space is another plus.
They would also work as an anchor for an exoskeleton if I ever wanted to go that route. All it is going to take is time and money.
Andy
Andy
