Heim Joint on Gear Shift>>REPLACED WHAT A DIFFERENCE
Trying to get my gear shifter adjusted properly. There is the heim joint (they call it a clevis in manual for some reason) that attaches to the shift lever on the gear box.
This is part 710.1.24.233.0
The ball has 1/16 to 1/8" lateral movement. I'm assuming this isn't correct? I'm having a difficult time adjusting the gear shift. It bounces all over when in gear.
Bad news if it's out of spec they are $69.39 at SAV. I did find that McMaster-Carr has a very good selection and some metric sizes if I can figure out what size it is.
Anyway, anyone ever messed with this?
1973 712M
Loosenes....
Look at the lower shift lever bushings, they are nylon and have a tendencey to disappear...
It's toast then. Have to measure it and find a replacement. Thanks.Jim LaGuardia wrote:Should be very little play, Mc Master or Applied industrial technologies, should have it, or King Bearing .
This started off as a search for an annoying rattle. Gear shift was banging around when driving in fourth. Hopefully this will tighten things up a bit.
1973 712M
Went ahead and replaced it with the SAV one. I can't believe what a difference it made. It tightened up the shift pattern. Got rid of a bunch of rattling from the shifter. Did the adjustment of the reverse stop bracket. Much easier to get into reverse now.
If your gear shifter is sloppy, you should check this part out.
1973 712M
Todd, On the heim joint you ordered, was it a nylon bushing or a grease joint? I think some of the noise I hear when shifting, is coming from this area.
