Radio antenna base removal
MB300GD
Post by MB300GD »
How do I remove my radio antenna base that is part of my canvas top? Then do I need to repair the canvas top after removal?
ka
Post by ka »
it just unscrews but often the inserts spin if the bolt is rusty. and yeah, holes in the top are left, but easily patched.
1973 710m
Most guys make a metal plate and use black silicone sealant to put over the hole 8)
ka
Post by ka »
one thing i learned about silicone adhesive is that it out-gasses in the sun, so it shrinks, so the bond line breaks and h20 gets thru. latex house calk (sealant) or "geo-cell" work gr8.
1973 710m
MB300GD
Post by MB300GD »
thanks - the Pinz won't fit in the garage with the base on
NC_Mog
Post by NC_Mog »
Sure it will. You'll just knock the garage door off its track, rip the arm off the door that the opener attachs to, and damage the door trim.
Not that I would know anything about it; I just heard about it from a "friend". :oops:
Kimball
1979 712M
ka
Post by ka »
HMMM. PINZ AIR.
1973 710m
norcal pinz
Post by norcal pinz »
my hardtop has a homemade piece of metal with silicone covering the antenna hole and it leaks i want to order the original cap and gasket for mine
710M 1972
710k 1974
Lightningpinz
Post by Lightningpinz »
After I took the antennea base off, I now only have to add 12 bags of sand to the rear and let the tire pressure down to 15psi. Viola It only rubs on the weatherstripping on the door frame.
M Wehrman
Post by M Wehrman »
******After I took the antennea base off, I now only have to add 12 bags of sand to the rear and let the tire pressure down to 15psi. Viola It only rubs on the weatherstripping on the door frame.*****
Unless you are into body building and to go anywhere you will need to air up.....how about 5lbs ,and 5 bags :lol:
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
LibTimothy
Post by LibTimothy »
I think you all are missing the most important point here.
You guys need bigger garages! Just explain to the wife - Big truck = Big garage. I'm sure she will understand.
Timothy
When the only tool in your toolbox is a hammer, every problem starts to look like a nail.
