Split Boot Replacement Tips
Posted: Tue Nov 04, 2008 9:45 pm
by texas pinzgauer
I've got a friend with torn boots on his 710. He's going to replace all 4 as a preventative measure. I directed him to Scott at EI for the new split boots and I've assured him that the boot replacement job is a piece of cake.
As I've not done it before, can one of you fine folks walk me through that process so I can download it to him along with any tips, suggestions or recommendations to actually make this an easy project to undertake?
Thanks in advance for you help!
Posted: Tue Nov 04, 2008 9:58 pm
by M Wehrman
Personally I would only replace the torn boots first. you will get dirty,
helps to "preload" the suspension (park that wheel on a 4x6 to level axle) and make sure the boot is warm(so it will stretch),clean and well glued. If memory serves,seams to the front on the Rt,to the rear on the Lt. Many don't like the split boots,they don't seem to last as long but are a bit easier to install.
Mark
Posted: Tue Nov 04, 2008 10:41 pm
by Erik712m
I agree with Mark. Would replace until needed Super glue works great. Also do a search Jim L. Has give directions as well but Mark pretty much sums it up.
Posted: Wed Nov 05, 2008 3:19 pm
by ScottishPinz
I did it a couple of months ago before Iceland
http://www.bagstraining.co.uk/Pinzaxelboot.html
Posted: Wed Nov 05, 2008 10:03 pm
by ka
i found the way i did it to be the easiest possible way to get those things on there. it's gr8 for when you have no idea what pinz's are about. i got wayne roberts to do it. i handed the screwdriver and glue to him.
wayne! we should have warmed them up! gr8 idea there, m wehrman.
