New brake pads won't fit?
Posted: Sat Nov 08, 2008 6:42 pm
OK, I'm sure I'm missing something simple here, so I appeal to the experience of the board.
I replaced a rear hub seal on my 712 (no problem) and needed to replace the rear shoes as well. New shoes (EI) went on one side no problem, but on the other side I couldn't get the drum on. I camfered the leading edge of the new shoes, with a little better luck, but I'd have to pound the drum on then the wheel would not turn whatever I did.
- Not the adjuster, as I had it all the way loose
- Not the cylinder, as it was adjusted all the way in
- Checked the old shoe with the new and they are identical, except for the new lining of course
- Checked, re-checked and checked again the installation of the different parts, and every time they are installed perfectly.
WHAT AM I MISSING?
Michael
WHAT AM I MISSING?
Michael
