power take off??
Locked
pinzi
Belgium
power take off??
Post by pinzi »
Dous anyone have the original power-take-off from a pinz,i know it exists and looking at the manual it bolds directly on the transfercase or is it on the hi-lo case...on the backside where the driveshaft is conected..more info about this is welcome. :roll:
off-road until i die
pinzmeister-uk
power take off
Post by pinzmeister-uk »
We had a fire engine through our hands which was fitted with a PTO driven pump. The PTO came off the main gearbox, not the transfer box. it then had a drive shaft up into the rear compartment for the pump.
pinzi
Belgium
Post by pinzi »
Yes i've have it in my manual...it's bolted directly on the back of the gearbox richt? but has someone pictures of that pice or how is chould be mounted on there.also where is the levler suposed to come,you know to disengage or engage the pump.
Locked
