Air Leaks
Locked
HOOPS PINZ
Air Leaks
Post by HOOPS PINZ »
I think that I might have an air leak. When I come to a stop after traveling at speeds around the 50mph the engine cuts out or starts to run rough then cuts out. She will then start up again and idle a bit rough until I press the gas pedal.
I cant find any air leaks any one had this problem ?
Thanks Steve
HOOPS PINZ
Just noticed that no 3 breaker had tripped reset that and the vehicle runs better.
Looking at the wiring diagram that seems to be linked to the lights.
Any suggestions
Steve
todds112
Post by todds112 »
HOOPS wrote:Just noticed that no 3 breaker had tripped reset that and the vehicle runs better.
Any suggestions
Steve
I can't find my list at the moment, but it sounds like it was the breaker for the idle cut-off solenoids that had tripped.
1973 712M
#3 is for the left low-beam headlight according to my schematic and #10 is for the idle cutoff solenoids. It's possible that your wiring setup is different or maybe it was changed by someone.
Paul
HOOPS PINZ
Thanks guys I will check those things out. My breakers may be different as my ignition light seems to be incorperated with the flasher light, they are constantly lit up dimmly and brigthens when I put the flashers on
Steve
Locked
