I think that I might have an air leak. When I come to a stop after traveling at speeds around the 50mph the engine cuts out or starts to run rough then cuts out. She will then start up again and idle a bit rough until I press the gas pedal.
I cant find any air leaks any one had this problem ?
Thanks Steve
Air Leaks
I can't find my list at the moment, but it sounds like it was the breaker for the idle cut-off solenoids that had tripped.HOOPS wrote:Just noticed that no 3 breaker had tripped reset that and the vehicle runs better.
Looking at the wiring diagram that seems to be linked to the lights.
Any suggestions
Steve
