Pinz has one power receptacle on the driver's left side, with a switch, mounted on the same plate as emergency lights (red) switch. But I found
one more identical connector in a rather unusual place, on the left side of
the central column (in front of engine cover) approximately in the place
where hand brake shaft enters the body. Very deep placement in a rather unexpected place. Has anyone used that receptacle? Is it switched or
straight from battery?
OG
Power receptacle in the central column
black out plug
I used mine to power a small fan on the right side of the wiper motor. Switched from the pull out type switch near the flasher module.
