Flickering parking brake light
Locked
texas pinzgauer
Post by texas pinzgauer »
Even with the parking brake off, the brake light on the dash seems to flicker intermittently. Any suggestions on how to prevent/address that?
Thanks!
1974 712M - sold
1973 710M - sold
That light also indicates if the brake fluid is low so that's a possibility.
Paul
texas pinzgauer
brake light
My wisconsin brother...thanks for THAT little tidbit of knowledge! I'll check the fluid level.
Thanks!
1974 712M - sold
1973 710M - sold
ablank
Post by ablank »
I had my brake light come on solid while I was sliding backwards down a hill standing on the brake. Is the flicker affected by vibration or hitting the pedal?
How'd this get here?
Erik712m
Post by Erik712m »
Could also be water in the switch. After Russ went way deep his light started to do the same thing.
chacaocop1
Post by chacaocop1 »
Water, Snow, any salty solution can act as a conductor in the switch. When I lived in Denver it was a common situation when snowing. Summer time it did not happen.
I know it was raining in Houston, did you drive it on the rain?
Carlos.
CHACAOCOP
1973 712M
ScottishPinz
Post by ScottishPinz »
I had same, light would glow dim after using hand brake and fording water, switch contacts were the cause. It is easy to get at under the truck, clean it up and all should be well.
Where is the switch for the fluid level?
The brake fluid level sensor is part of the fluid reservoir cap(s). I have seen one model of the reservoir that didn't have the sensor though.
Paul
texas pinzgauer
I checked and the hydralic fluid level is fine.
So what's the 2nd most likely cause for the flickering brake light?
1974 712M - sold
1973 710M - sold
Post by Jim LaGuardia »
Look at the park brake switch and contact tab. Aslo make sure the lever is not flopping up and down due to a missing washer.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Twin Pinzies
Post by Twin Pinzies »
Jim LaGuardia wrote:Look at the park brake switch and contact tab. Aslo make sure the lever is not flopping up and down due to a missing washer.
That's what the problem was with mine.
Mine was just flashing on and off while driving. Sounds like a low fluid situation, since it only happens when using the brakes, and I know I need to readjust them (long pedal throw). Very timely thread! Thanks.
Locked
