4500 rpm light Is there a test?
Posted: Fri Jun 05, 2009 12:04 am
by norcal pinz
i'm wondering if there is a way to test this system i have never seen my light come on and i want to know if it works properly. also don't know where it connects to ,the engine somewhere ? thanks everybody!
Posted: Fri Jun 05, 2009 12:22 am
by Foz
4700 rpm oughta do it
min rpm's??
Posted: Fri Jun 05, 2009 12:40 am
by ka
on this note, does anyone know the min rpm's? i just noticed that the other set of numbers is refering to low range max rpm's. i always thought it was min because i never looked close enough.
Posted: Fri Jun 05, 2009 3:36 pm
by todds112
When you first turn key on it should flicker. I still wasn't convinced mine was working so I ran it up in low range till it came on. It REALLY made a racket. I don't suspect you would ever see that RPM in normal use.
Posted: Fri Jun 05, 2009 3:58 pm
If the light flickers when you first turn on the key, the module has passed it's function test.
You know, you could just install a tach if you just have to know the rpm's.
Posted: Sat Jun 06, 2009 12:28 am
by norcal pinz
thanks guys for the flicker info i cant wait to check! tach no way i like them bone stock who needs that when your practically sitting on the engine right.
PINZGAUERS RULE! thanks guys.
Posted: Sat Jun 06, 2009 9:24 pm
by MarkPinz
Mine came on once while descending a long steep grade on the highway
Posted: Sun Jun 07, 2009 10:46 pm
by norcal pinz
downhill on the highway you were probably hauling ass and it came on to say slow down.
