I need to re-bush my carbs and can't find any info on the proper size bushings to use. Anyone done this before and have a size and source for them.
The process seems straight forward and I have all the tools needed for the job.
Miles
Bushings for carb shaft play
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Miles, there is an oversize steel shaft available. My old shaft was brass and had visible wear. I used the oversize shaft and it took care of the slop. Apparently there is a throttle base version that was machined to accept seals. I think Denis at Linden Engineering was also machining bases to accept seals.
It really helped with the gas leakage and being able to sync the carbs up.
Here's the post I made about it with pics:
http://real4x4forums.com/PinzgauerBBS/v ... ttle+shaft
Hope that helps.
Hope that helps.
carb bushings
Take your carbs apart and take the bases to any carb rebuilder and they should be able to rebush them for about $50.00 ea.
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
