OK, before I get started, I am not a mechanic, although I do all of my own Pinzgauer maintenance...like that takes a genius. I've owned a 710 for almost 10 years.
I removed the air diverter assembly off of the air cleaner, as the climate where I live never requires the winter setting. Now I have a 2 1/4" hole directly into the air cleaner housing. I capped off the other end of the hose where it connected. Now for my idea...
Looking at the tin housing right behind the fan, I see room for a 2 1/4" hole to be punched in, right in front of the oil fill tube. Now connect an 8" hose from that new hole to the intake of the air cleaner assembly, and you now have a turbo effect. Yes, laugh if you want, this might be totally crazy...or is it??
The new opening I mention is right behind the cooling fan, so you would get some 'boost'. Of course there are things to consider, like the cooling effect on the engine, and whether or not the engine could handle the added aspiration, or added compression. The stock set-up may not work with this modification, but what do I know?
What do you guys think, especially Jim and the Professor? Yes, there are a lot of physics to consider if modifying like I suggest. This might also eliminate the lag that is so inheirant to Pinzgauers??
I suppose the worst-case scenario is to give it a try, and plug the hole if it doesn't work. This might cost $20 if you do it yourself. Any good electrician has the tools to punch the hole correctly.
Here's an idea
Re: Here's an idea
You would have to be moving pretty quickly to force positive air pressure into the bay. It may cool it slightly better. Cooler air = more power in much the same way as a hood scoop.pinzinator wrote:OK, before I get started, I am not a mechanic, although I do all of my own Pinzgauer maintenance...like that takes a genius. I've owned a 710 for almost 10 years.
I wonder if it would be best to load a scooped port in there, say from a car stereo shop. Something that has a nice bevelled edge.
I checked with a good friend of mine who is an instructor at Wyotech (Google Wyotech and see), and asked his opinion about using the cooling fan for assisted aspiration. Here is his reply:
<Don't screw with your homemade turbo. We had the urban myth-busted at Laramie regarding a leaf blower injecting air into the intake of a 3.8L Camaro V6. We had the car on the chassis dyno and baselined it without the leaf blower turbo; hooked the leaf blower into the intake and LOST 5 rear wheel hp!>
So there you go. Just like I figured, there's more to it than connecting a hose to a fan.
