Ok, I have only been a Pinz owner for 6 months. (1973 710M) I am trying to work out all the bugs in my vehicle in my quest to make it an awesome adventure traveler.
Today, my Pinz started acting up. I had not driven it for a few days. Today, when I pressed in my clutch pedal, she squeeled like a stuck pig. It did this all day. At this point my guess is the throwout bearing.
Then 3 miles from home, I am at a stop sign and BAM! The transmission engaged while I had the clutch pressed and the vehicle stalled on me. The clutch was no longer functional.
I started it in second gear and was able to shift on the fly into third and nurse her back home.
When I go tearing into this on Monday, what should I be looking for?
Clutch Problems
Clutch Problems
If you are not living life on the edge, you are taking up too much space!
1973 710M with aftermarket hardtop.
Could just be the release bearing exploded. I had to do my clutch over x-mas, not a hard job at all, I had the gearbox out and sat on the floor within an hour without a problem. Probably worth doing this before you order any parts - you'll kick yourself if you buy a full clutch kit and its just the bearing...
