Clutch Problems
Posted: Fri Jul 03, 2009 10:20 pm
by goalsquid
Ok, I have only been a Pinz owner for 6 months. (1973 710M) I am trying to work out all the bugs in my vehicle in my quest to make it an awesome adventure traveler.
Today, my Pinz started acting up. I had not driven it for a few days. Today, when I pressed in my clutch pedal, she squeeled like a stuck pig. It did this all day. At this point my guess is the throwout bearing.
Then 3 miles from home, I am at a stop sign and BAM! The transmission engaged while I had the clutch pressed and the vehicle stalled on me. The clutch was no longer functional.
I started it in second gear and was able to shift on the fly into third and nurse her back home.
When I go tearing into this on Monday, what should I be looking for?
Posted: Fri Jul 03, 2009 10:29 pm
by audiocontr
Buffalo Eh? I'm originally from East Aurora. I know a great mechanic down there if you need one.
As far as I have read, you want to check for the clutch disc shattering. Otherwise its a couple hour job to swap them out. A little pricey though!
Posted: Sat Jul 04, 2009 3:21 am
by psychoman
Could just be the release bearing exploded. I had to do my clutch over x-mas, not a hard job at all, I had the gearbox out and sat on the floor within an hour without a problem. Probably worth doing this before you order any parts - you'll kick yourself if you buy a full clutch kit and its just the bearing...
