ABSOLUTSECURITY
Post
by ABSOLUTSECURITY » Mon Jul 13, 2009 1:14 am
Got it in
- now I have to power her up!!!!!!!!!!!
Glynn
todds112
Post
by todds112 » Mon Jul 13, 2009 8:35 am
Looks great! That should be nice and comffy. The ambulance box looks pretty thick!
ABSOLUTSECURITY
Post
by ABSOLUTSECURITY » Mon Jul 13, 2009 9:06 am
Thanks! I have to take it all off again to run 12 ga wire to power it - I was going to use the wire from the dome light but its 18 ga or close to it and that just wont work
- lucky enough there is a chase/conduit that the dome light wire runs thru and I will just pull 3 new 12 ga cunductors thru there!
I will post pics of the re-wire also.
The box should be the coldest thing around - that is fiberglass/foam/fiberglass and its like an Igloo!!!!!!!!
Next two double pane insulated windows go in - one per side!!!!!
Glynn
texas pinzgauer
Post
by texas pinzgauer » Mon Jul 13, 2009 10:33 am
The step by step process by which you successfully add air conditioning to your truck should be of great interest to every K or AMB owner on the forum.
I noticed those bada$$ headlights too!
ka
Post
by ka » Mon Jul 13, 2009 10:39 am
glynn - could i get the location of your pix? i'd love to have full res versions of those!!!! my heart jumped when i saw that truck...
1973 710m
ABSOLUTSECURITY
Post
by ABSOLUTSECURITY » Mon Jul 13, 2009 2:27 pm
ka wrote:glynn - could i get the location of your pix? i'd love to have full res versions of those!!!! my heart jumped when i saw that truck...
I will email them to you later ok!!!!!!!!!!
G
ABSOLUTSECURITY
Post
by ABSOLUTSECURITY » Mon Jul 13, 2009 2:28 pm
or you can go to photobucket and go to my account absolutsecurity
G
Post
by Jimm391730 » Mon Jul 13, 2009 3:06 pm
So, Glynn, what did you run into when you cut into the box (besides fiberglass and foam)? Did you hit any metal framework, and if so, aluminum or steel?
712W (hence the question) and 710M
ABSOLUTSECURITY
Post
by ABSOLUTSECURITY » Mon Jul 13, 2009 4:44 pm
Wide open fiberglass/foam/fiberglass - I looked inside and eyeballed where I would want it then got up on the roof and positioned a full size template of the AC unit footprint on the roof and figured where I wanted that and pretty much hit it spot on - I took out the dome light that intended to use its wiring for the power to the AC (wire is 18ga so I have to run 12 ga) Everything worked out nice just a itty bit of the dome light cavity not covered by the inside cover maybe an 1/8 inch showing - I have to take the inside trim and mechanism down and pull the 12 ga into the heater space form the dome light cavity and then I can mount and wire in the Inverter.
I will take pics and post as I go!!!!!!
G
Erik712m
Post
by Erik712m » Mon Jul 13, 2009 5:41 pm
Looks good... heat pump?
Are you installing a second set of batteries?
ka
Post
by ka » Mon Jul 13, 2009 5:47 pm
glynn - yes! please send full res of whatever! i have trouble accessing others' photobuckets accounts for some reason.
1973 710m
ABSOLUTSECURITY
Post
by ABSOLUTSECURITY » Mon Jul 13, 2009 6:11 pm
Erik712m wrote:Looks good... heat pump?
Not a heat pump but heater element is installed so its a heater also!
I have 4 yellow top D31 optima batteries for house power that I will be installing just under the heater cabinet area in the valley of the bed I think , I have to figure a little more- that should be a nice battery bank for house power.
G
karoja
Post
by karoja » Mon Jul 13, 2009 6:42 pm
Nice! What brand of A/C is that?
Jon_Gilbart
Post
by Jon_Gilbart » Wed Jul 22, 2009 7:57 am
That looks really cool--I also would like to know the brand of the A/C unit you have there. I have a 712M, and have been thinking about buying an ambulance box and doing a similar thing w/ the A/C and heater.
Not to hi-jack your thread, but I've also been thinking of how to increase the headroom in the ambulance so that I can stand up straight. It would be pretty neat to turn it into a camper, and the A/C goes a LONG way to making that a reality. I was thinking of trying to section the box all the way around and add some sort of a soft tent-like section in the middle and use hydraulics to jack up the top when I want to. I'd like to keep the height as low as possible when using it off-road to keep the center of gravity low and not have to worry about banging the high top on every tree branch. This is probably just a pipe dream, though, as I don't have the time or skills (or garage space for that matter) to tackle that project by myself right now...
